Revell P61, waiting for the hammer to fall
Thank you, you old "show how it's done" group build buddy! I still say I'm "box stock" because any details are just replacements for what's there and not a complete replacement of anything.
I apologize for being so far behind with this, but it is coming along...
In my usual fashion.
Rob.
Well, keep on keepin' on, looking great!!!
Join in right here! We're all well into this thing, but I'll scooch over. It'll help me anyway. I can't read or write, so you can tell me what I'm supposed to be doing "as per the Instructions".
Rob.
This group build stuff is insane!
Loved looking through the builds, the comments and the 'esprit de corps' ... and still more to come!
Well done all!
Ok, just to add more to a group build that most have long moved on from, here's to revive it from time to time.
I've done about as much hand painting as I can stand, but that is wrapping up now.
I did a little wheel work and here's how that came out. I opened them up and added some tread.
Here, as I said before, are a little more of the modifications.
Since I wanted both engine cowl sections open, as mentioned, I picked up that extra set of parts. Both the left and right booms will be the same on mine with open cowl flappy thingys. On the originals, each cowl flap is filled in between the sections. From what I can tell, there is another flap section just behind the outer cowl flaps on a real plane that probably open the outer cowlings. I don't know for sure because I can't find a picture of any engines from the rear showing forward in this area, so I just figured there is and made some. On many of these planes on display today, those inner flaps are colored and I think it looks nice, so mine will be red.
Here's what I'm talking about as many that haven't seen this kit won't know what I'm talking about, but those that have built it will understand.
I dressed up the engines a little.
Here's the inner flaps I made.
Here's how it all fits together. Those new flaps will now hold everything together and fit on those dowel pins for alignment and that main center pin will hold it all to the boom section.
It should be alright? Anyhow, moving slowly down the track.
Rob.
View attachment 134434View attachment 134435
Rob.
The details are fantastic. Pantherman
Thank you P-Man.
These are just simple things that I'm adding and still keep it box stock.
I took note of the weight you added and to make it stay on the front wheel because I certainly want that. 60g is alotta fishin' lead!
Rob.
A little closer! I really need to slow down some. As y'all know, I work at a break-neck, high stress pace that would kill a normal modeler. I do not recommend it.
I have attached the "booms" to the "wings". Still no filler. I did, however, have a small gap just behind each wing where they attach to the boom. Instead of filler, I was able to add some .010 sheet styrene into the slot and smooth out the area. All I can do is hope it's slick when paint goes on.
To go with the "new" see through mesh I added under the boom sections, I wanted something in there to see now. I know y'all ain't gone believe me, but all them noodles and pipes are EXACTLY what's on the real thing. I can't prove it and I couldn't find one stitch of research to back that up, but trust me.
100% accurate.
Here's what you see through that mesh. Not alot, but a little sumpim-sumpin.
I also took Pantherman's sage, sound and professional expert advice and want this thing to rest on all them wheels, so I added weights. Ok, P-man said 60 grams. What I used is a cut-up, squished and flattened post type battery terminal. Solid lead, so I figured it'll work. By the time I got through with the trimming and cutting and smashing, it ended up at around 28 grams in each wing boom and this will all be mounted right behind the engines.
I ended up with what I put in the wings right at P-man's suggestion. I wanted to be sure, so more went into the nose section. I had to improvise once again and find some weight material, so to the nose section I have added 1 .44 magnum 300 grain soft hollow point, half a .357 Magnum 180 grain soft hollow point and 3 .22 Long Rifle bullets. I squashed 'em flat and fit them into the area P-Man said to in the nose area just behind the radar plate for the model, which is an open area. This all added up to about 22-24 grams more, so I should be alright. Total, about 70 grams. Ish.
I didn't add anything to the nosecone, because just like P-man mentioned, I wanted to display the radar. Saying that, I built the radar, added a little detail to it like springs, hinges, tubes, wires, coils and such trying to simulate what I seen in pictures of it.
Here's what I ended up with.
I've also got the main fuselage assembled. I plan to have this thing all buttoned up, so I had to do a little filling along the bottom.
That very rear hatch seems to have never been meant to be closed on a finished model and I ended up having to add some styrene at both ends and smooth all that out. Here again, paint will tell how this came out.
I've had to deviate from the normal assembly steps listed in the instructions having this all "flight ready". The internal guns are mounted, but I have cut each gun tip off, drilled both sides of the barrels and will add each tip back once this is all painted.
There's where we are.
Rob.
100% accurate.
Rob.
That's some mighty impressive work. Thanks for the mention, hope it helped. Can't wait to see the finished build. Pantherman
I have two of these in the stash. Thanks for the inspiration—and a little intimidation. Now I'm going to want them to look like yours!:eek::D
Of course I mentioned you, it was your tip. That woulda SUCKED later. We're all in this together. I know I'm lagging far behind y'all and I appreciate stopping to check on me!
Well jump on up in here! Inspiration I certainly appreciate, but never be intimidated by what I show. If I can, ANYBODY HERE sure can too.
Like Pantherman said, very impressive work.
Thank you very much!
Rob.
Little more progress to chime in on!
We gots a canopy with lines on it.
Does it have flaws, of course, but it didn't come out bad enough to smash it with a hammer and it'll work, so I'm alright with it. As I said, I'm building everything all closed up like it's sittin' on the runway ready to go on a killin' spree, so I've glued all the openable pieces in place.
Other than that, it's all painted except for the remainder of any hand painting that'll have to be done.
Again, the flaws are minimal. The more I have to handle it, the flaws are increasing, so I really need to finish this... before I throw it in the garbage.
Still need to finish paint them wing scoopy things and a couple other details, but she's a gettin' closer.
P-Man, I ended up having to add even more weight to mine since I didn't add any to that nose cone, but it's on it's wheels, so finally got enough. It weighs three times what it did box stock, that's for sure.
Rob.
