So as promised I will try to make a scratch built Baneblade. And you might think i will be using evergreen material, sadly no. That would run up my budget fast, so instead i will be recycling everyday items combined whit hobby material. So these are the tools i used so far.
So for the frame I will be using those annoying Cd covers that you got laying all over the house, I saved up all of mine and ended up whit 2 grocery bag's full of them. And the scratchier the better, trust me. So grab a stack and remove the lids to start whit, oh and remove those annoying insert as well. You'll be needing about 16 of them, depending on how good you are whit the saw.
Fist of were going do do the front part, first cut should be about 1" ore 25 mm MAKE TWO. If u want u can smother out the part that remains, second cut should be about 2, 3/4" ore about 70 mm MAKE TWO. The smaller part is OK, but if you try fitting the front on later you will notice that the top is to big. Will be adjusted later. !!! WARNING DO NOT REMOVE THE INLAY STOP ON THESE PIECES !!!
Gluing the two parts together side by side wont hold up very long, so to help them I'm gluing down long sanded down sprue's from my GW models. And it helps if you take a sand paper and run it along the side were your gluing, and simply use the natural slanting of the sprue to get that V shape in the front.
Cutting out the peaces for the bottom, you'll need to cut after the doted line
. Just cut away the sides and the stop for the inlay on the inside and you'll be fine. Make 4 full size parts and 2 half size parts.
Now for the top (the lid) I opted for keeping that stop on the back until i have glued it down securely and then grind it down. We will also be using the part that was left over from wen we did the front.
Wen you get this far put it aside for now. And the observant viewer will notice that i used smaller strips towards the front (my bad, didn't find my leftover). So at this point it is about 302 mm long
Will post the rest this afternoon.
