Hello peoples. Long time no see. I got myself injured and had to be operated. But everything is fixed now and I continued to work on my Banshee. Haven't updated here for a while, so I'll let the pictures do most of the talking.
The Details I put in the trenches on the main cockpit sides. Veeery tiny bits, which I partly got from 1/72 Tank kits and had to scratchbuild, since even 1/72 Tank kits don't have enough small bits for that.
Then I finally started on the cannons. That weird brass tube gave me quite a hard time sawing it and sticking it together with superglue. I got very angry sometimes.
Here's the canopy with added stripes of sticky foil. I wanted to use 0.2 mm PS Sheet at first, but that was too hard to work with. I had to use superglue for the PS stripes and more often than not they were sticking to my fingers instead of the canopy. So I came up with the foil which looks quite ok as well. I just hope it doesn't deform too much over the time. :-\ Oh and I actually had to re-do the canopy
several times. First it didn't fit properly, then I accidentally destroyed it, then it didn't fit AGAIN and then I thought about making everything out of one piece, instead of two. Hehe.
Here are the cannons with some Aves Apoxie Sculpt put on them. That stuff is really incredible and a joy to work with, even though it's veeery sticky.
Then, work started on the pilot. I first wanted to use a 1/72 Tank officer, but he was too tiny. So I eventually bought a set of 1/48 Jet Pilots and voila! Fits perfecty and already has a cool helmet on..
I still had to alter the pilot's position of legs and arms a bit. I also added a head cushion on his seat, so that his neck won't get wrecked in battle.
Oh you can also see the pilot's joystick, which I added out of thin PS stripes with a glob of glue on the end.
Added foot pedals!
