Hello again!!!
Back at this one, I have made some more progress and thought I would share a bit more.
Let’s get to it….
When I left off the last time, I had the lower hull masked off and I was getting ready to begin painting the rest of the weather deck and upper hull.
Well, I began!!!
I picked this up from
AK Interactive USA
AK’s
German Panzer Grey Modulation Set!! I was interested in seeing how I could apply this to the Yukikaze. Only one way to find out!!
First I needed to mask off the weather deck section I had painted previously.
Starting out with some Dunkelgrau Shadow and Dark Base.
I lightened the entire upper hull with light base.
Next I added some High Light.
After sliding in some modulation…
Getting back to some of the construction, I snipped off some of the forward superstructure and started gluing.
In this section there is a clear piece that needs to be installed in the main bridge. I need to actually paint the deck section to match the red/brown coloring of the weather deck and then the greys.
Taking a closer look I have applied the kit supplied PE to the sides and front section of the bridge as well as the deck supports.
I added the rear funnel and a started cutting PE ladder sections
Finally, I added the remaining PE to the first triple gun mount.
With that, I have ONE gun complete!!! :-X I can see these might take a little time….
Back to gluing more deck features and prepping for more paint….oh yeah, working on all the guns too!!! :
As always, thanks for stopping in!!!
