Papermodder
- Jan 2, 2013
Good evening.
An update on the Refit.
Working on the secondary hull, finished the framework.
The next step was to assemble hull's skin. At this scale it is easier to work on the skin separately. Easier to compensate for any problems and the shape.
The completed skin is then applied to the frame and glued together at the top seam. The glue tabs at the front of the hull are attached to the front of the frame. The front extension piece that was previously assembled is the attached to the front of the hull. As well part of the hanger deck was installed and the filler for the bottom of the hull was installed.
Still a lot of work to do on the Secondary hull.
Thank you for following.
Jim
Jim
