Thanks Solander
Bit more done
I assembled all the tail feather parts ,sanded all the edges then done a dry fit ....pretty neat
Then moved on to tackle those Huuuuge wings ! .After joining the havles of the outer wing panels they then need fixed to the centre section .To be honest I was expecting a few problems here simply because of the way everything joins together. Basically you have four havles meeting in a butt join along with two spars to help hold everything . Its very important to make sure all the joining faces are as smooth & flat as possible ! If not ,you're in for a world of hurt
I got everything as neat fitting as I could ,but still ended up with a little filling to do (again to be expected ) ,Once I had joined the wings I filled up the seams with CA ,then when it was dry I wet sanded it ,this was followed by a coat of Tippex (correction fluid ) just to take care of any pinholes there may be in the CA . Again the Tippex was wet sanded to finish .
Apart from those joins ,the rest of the wing is a good fit with the leading /trailing edges just needing sanded . ....Its a big wing !!
Again ,once I had finished I did a dry fit to the fuselage ...just to check
....its all good ;D
Just for a laugh , A size comparison with a 1/72nd Zero Im working on over in the Secret Santa GB ;D ...she's a big ole Bird ;D ;D
Thanks for looking
