Thanks, Can you tell me the brand that you use for the artist oil burnt...View attachment 116045View attachment 116046View attachment 116047Tamiya deck tan is good. Let it cure a couple of days then give it an artist oil burnt umber wash to darken and pop the grain and recessed details
Awesome! ThanksHobby Lobby is my go to place for these things. I used raw umber but burnt umber will also work.
Awesome! Thanks
Is that Murata's Type 97 Kate?View attachment 116045View attachment 116046View attachment 116047Tamiya deck tan is good. Let it cure a couple of days then give it an artist oil burnt umber wash to darken and pop the grain and recessed details
Thank you very much for the detailed information. Big help.for reference regarding burnt umber vs raw umber
Also something for consideration if using oils is you need a thinner/cleaner. I would suggest Weber's Odorless Turpenoid. I have found that to be the mildest as far as reactions to Tamiya paints or certain types of plastics (like Bandai's) vs some of the harsher turpentines/mineral spirits
In addition you may even consider Artisan oils (Windsor Newton makes them and you can find them the same places you find regular oils).
The difference is you can get away using water in place or turpentine or similar. Although you can still use things like the Weber Odorless Turpenoid if you need a bit more help in cleaning away a sludge wash
