Pantherman
- Feb 10, 2022
Had to make the last pipe as the little devil disappeared on me. It probably isn't correct but most of it won't be seen.I have almost finished the tube, just some engine pipework to fit. I have test fitted the interior tube into the rear hull and fitted the front hull, very happy with the fit.View attachment 112695View attachment 112696View attachment 112697View attachment 112698View attachment 112699
Now had to think about how on earth I'm going to light this up as never done much electronic stuff so massive learning curve.
I marked the position of the front hull onto the interior tube bulkheads so that anything I do can't be seen when assembled. I have now cut back small sections of the top bulkheads with a view to getting cables along the top of the area's, then bring them around the rear section and back under the batteries to the middle of the lower hull.
I have in my head an idea to drop all the cables down, through the stand provided and into a a long thin box which will contain all the connectors, batteries and a switch. Like I said, it's all in my head working perfectly but in reality it might not happen !!!!!
If it all goes wrong then I will still have the unlit sub as anything I do for the lighting will not be seen. Pantherman
I had forgotten about lighting the coning tower so this is what I have done. Pantherman
