Biskup
- Aug 27, 2010
I would recommend this if I wouldn't test it my self. The only trick is to add it after you add water.Elm City Hobbies said:Biskup said:I would say it's not mixed enough with Vallejo I always prepare the paint in paint try then I put it in the air brush. It's almost impossible to mix it well inside the airbrush. Second thing is that it might not by thinned enough. It's good to add some Tamiya thinner or some other alcohol based thinner it just works better.
Cheers
Lukasz
DO NOT ADD TAMIYA THINNER TO VALLEJO PAINT
I can not stress this enough, that is unless you like cleaning a gooey mess out of your airbrush.
Tamiya and Vallejo are both acrylics, but are not the same type of acrylic. Tamiya acrylic thinner will actually gel Vallejo paint.
DK....how much are you thinning it? Just sounds like it isn't thinned out quite enough.
Regards
