printables
- Jun 27, 2023
Hi and welcome to the forum. PanthermanWhat it says on the tin. Does anyone have any advice on how to scratchbuild the metal bars that keep everything in? Thanks in advance.
Sorry for not being clear enough. I've circled it in the attached picture, but basically I'm trying to 3d print an Abrams and I don't think my printer will be able to do fine details like the rods on the stowage rack. I was wondering if y'all knew any way to scratch build that at 1/72 scale.Welcome. Show a picture of what you mean, if you would.
Happy to be hereHi and welcome to the forum. Pantherman
Interesting, I'll definitely give this a looksie. You have an recommendations for tutorials? Or just what size to use of brass or styrene rod for 1/72 scale? Thanks.Old-school would be to use styrene rod, heated to bend it to shape. Or brass rod, bent to shape and soldered together. I'd make a jig from a a block of wood, to use to get the right size. And pieces of styrene strip or card stock cut to size, for the support brackets. L-profile angle stock, for the bottom frame.
I could do that and I might end up doing that, but I would prefer to be able to see things like the stowage and AC unit. Do you have a preferred way of doing tarp covers?Why don't you put some junk in there and cover it with tarp
Tamiya epoxy puttyI could do that and I might end up doing that, but I would prefer to be able to see things like the stowage and AC unit. Do you have a preferred way of doing tarp covers?
Or maybe tissue & PVA glue
