TRM said:SMA Lunch Menu
Tank on base ................$5
Tank on base w/figure....................$5
Tank w/ side of fries . ...................$7.50
Tank Supreme; comes with 3 figures, one tree, side of fries and your choice of soft drink .........................$8.25
(leaving now....where my coat :)
f2k said:Scott Girvan said:If a kit had a figure included, and you made a simple base with terrain or trees stuff like that would it fall into Diorama Category.
Am I the only builder who always base his models? I just think it adds that final touch to the model.
When I asked about dioramas last year I was told that, if it showed a story, then it was a diorama. I think this was a good way of doing it. Placing a tank on a base with a bit of sand and grass isn't really, in my eyes, a diorama. Placing it on a base with attending ground crew doing repairs - now, that would be a diorama.
Your call, of course. I'm just a bit bummed that I might have to leave all my builds "unfinished" or enter them all into the diorama category...
Ha!
"All"...
I should probably be glad to finish just one... ;D
Elm City Hobbies said:f2k said:Scott Girvan said:If a kit had a figure included, and you made a simple base with terrain or trees stuff like that would it fall into Diorama Category.
Ha!
"All"...
Go to any show, tank on a base with any ground work, whether it has a figure or not, is considered a diorama, or at the very least a vignette.
I entered a ZSU 23/4 into an IPMS contest once, and I had it on a base, with the only ground work being a coat of sand, with a small piece of a stone wall....no figures on the base or on the vehicle, and it was classified as a diorama.
If you put your tank (with or without a figure) on a simple wooden plaque, with ZERO ground work, it is still classified as an armor entry.
However that same tank (with or without a figure) on the same wooden plaque, with gravel, sand, and/or grass simply attached to it to make it all aesthetically pleasing, makes it a diorama.
The whole point of a diorama telling a story, is a good rule to live by....but just because it doesn't tell a story, doesn't necessarily not make it a diorama.
4.10 Bases/Dioramas. Bases will be allowed in all categories and will not be considered in the judging except in the Diorama classes. The use of display bases is encouraged to help in moving models. If used, there should be a note indicating whether the model is attached to the base or not, either separately by the contestant or as a check-box on the entry form. A base may be a piece of undecorated wood, plastic or glass or it may simulate the natural surface on which the prototype would be found. However, nothing other than that surface may be used. Aircraft and military vehicles may rest on simulated ground or paving, and aircraft that need beaching gear or dollies may be so equipped. Ships may be displayed in water. The base must not be the predominant feature of the entry and must be of a size proportionate to the model. The Chief Judge and judges reserve the right to exclude oversize bases. The model may include primary crew figures. The addition of any other figures or equipment outside or not attached to the model (e.g., support equipment, shell splashes, or buildings) will make the model a Diorama, which should then be entered in the proper Diorama category. However, if a contestant prefers to enter in a strictly aircraft category (i.e. non-diorama), then it must be clear that the accessories on the base will be ignored during judging. Dioramas are judged not only on the technical merit of their construction but also on the strength of the theme or story they present, so that if two dioramas were technically equal the one having the stronger theme or story would win. A previous national contest winner may be used as part of a diorama as long as it not the primary focus of the diorama.
Scott Girvan said:Yeah, we have to keep everyone on the same playing field. So if it's already been worked on, to any degree, it is ineligible.
Eastrock said:Chris, Good Questionare you a rugby player (avatar) ;D
Chris S said:So what category does a single figure or bust go into then ?![]()
Neo said:Red leader standing by!!
Ha!
"All"...
Black Sheep 1 said:Elm City Hobbies said:f2k said:Scott Girvan said:If a kit had a figure included, and you made a simple base with terrain or trees stuff like that would it fall into Diorama Category.
Ha!
"All"...
I'm trying to understand the "telling a story" vs "not telling a story" concept you guys are talking about.
To be they all tell a story, how detailed the story? Depends on the detail of the build.
Example:
Take an M1A1 just sitting on a base with some sand. To me it says this tank is waiting to move or ready to fire.
Take a Tiger sitting on a base with dirt. But the tank has some bent road wheels and the track is all bent and broken. There's a hole in the side of the hull and some burn marks. Well that tells me this guy got blown up!
So, when would it not tell a story? To me it would be a model displayed on a plain base or no base at all. Yes? or No?
Neo said:oh almost forgot the most important question !!
Do we get to see Grendels lovely assistant this year ??
spud said:Lol no she is for his eyes only ... Jammy git ;D but im sure when she can and is able to come on mabe she will,
