OK, another update. For not actually being a huge update there are a few pics just to show what is going on.
I alluded earlier to cleaning the office walls in preparation to installation. I was not to happy with the interior pin marks on the walls, but I also realize the EPM's need to go somewhere...might as well been inside. Here are the cleaned up parts as I work the walls.
In keeping the SBS with the instructions these are the parts for step 11.
Moving onto step 12...
While dry fitting everything I came across this little one. You can see the back of the communications equipment through the window here.
When complete this can be seen but if painted the same as the rest of the equipment, a dark color, it will be seen but look like it is just what it is suppose to be. You could take the time to cut a small piece of card stock and cover the back.
I am actually going to paint up the interior soon as I work my way through the build...this means I need to do it now as I cannot attach certain pieces until I attache the cabin walls... Heading to the booth some night this week!
I have to let you know...half of the EPM's are not even seen since they are obscured by the equipment there will be some that need attention. I used a combination of two methods...simple sanding and filling and sanding...both the same in my eyes...both tedious but need to get done.
There you have steps 11, 12 and 13. I have not glued the interior window parts as well as a couple of parts that need to stay off so the window can be installed after painting.
And finally...this was in the mailbox today!!! Straight from Dessert Eagle Publishing, the DOOBI D9 Variants: D9 Bulldozers in IDF Service book!!! I have begun reading through it, not only to gain more knowledge of what I am working on but I will have a full review of this book real soon as well.
As always, thanks for tuning in!!!
[attachment deleted by admin]
