Messerschmitt Me-329
Good evening.
Time for and update.
I had set myself a goal of finishing all the exhaust stacks this weekend. Alas it was not to be.
Put quite a few hours on the bench, but was only able to finish the stacks on one engine.
Building each stack one at a time was becoming a very slow process. I did come up with a system that has sped this up a bit.
With one engine done, I could not resist getting it mounted into a wing.
It does give a feeling of moving forward, after so long with these engines.
Still working away on the second set and hope to get them done soon.
I can't believe how quickly the end of the month is coming. I'm hoping I can get this done in time.
Thank you for following.
Jim
I was beginning to think these engines were going to be a neverending story.
Tonight the right engine was finally finished and installed into the R wing.
The goal is for tomorrow to start adding skin to these wings.
Other than the panels over the engines most of this should go quickly. ( I say with trepidation as I've probably cursed myself. ;D )
Jim
Thank you Patrick.
The panels over the engines are removable, to view the engines.
Jim
Good evening all.
With the good weather finally upon us, along with some family obligations, I have had a hard time getting bench time as well as my modelling mojo in gear.
This past weekend, was finally able to get some work done, skinning these wings.
First of all got the inner wing area covered and cutout the landing gear bays.
With that complete, started on the outer wing skins.
The kit did not supply a bridge strip to the engine bay for the outer skins. I need this to support the skins over the engines.
Was able to use the strip from the inner skins, as it is the same shape, just shorter. So reprinted that part for this application.
Shaped the leading edge to the contours of the ribs and glued it into place. Used clamps to hold the trailing edge closed and in position.
When that dried, then worked on the wing tip.
The tip was given a slight curve, then edge glued along the outside edge.
The tip was then glued in place and left to dry.
This was repeated for the other wing.
This is where I am at this time.
I'm hopping to get this project done on time. We'll see.
Jim
I'm sorry to report that this build will not be completed for the deadline.
It will get completed and I will not rush it.
Hopefully next year I can find a project that will be able to be completed on time.
Jim
Thank you Cave Dweller and Patrick.
Yes it will get completed, just too much of life interfering with bench time lately.
Jim
