NYLON GAG MK 1 - FINISHED
Re: NYLON GAG MK 1?
This is looking mighty sweet !
Keep working at her... she will be a keeper once you are done...
Later !
nice effects with the metalizer paints pretty nifty !
Re: NYLON GAG MK 1?
Lighting looks awesome NG!!! Nice tat as well. ;D
Re: NYLON GAG MK 1?
Ello Chums,
Thanks again for the great comments, glad you like the lighting.
This last week i've concentrated on adding a bit of detail to the front intakes, painting and weathering the intakes and weathering of the engines.
Also i've attached the engine fairings to the main body.
Front intake with some simple detail additions, wanted to keep these fairly clean
Then gave them a coat of black primer then a top coat of Metallic grey and titanium silver
Then gave the whole thing a black pastel wash, with more intense colour at the front of the intake, then a heavy drybrush with crome silver
Gave the deflectors and the engines a pastel wash with black and a light wash with brown, then a very light drybrush with crome silver again.
Later i will do some more streaks and dirt with oils but for now i'm happy with the look.
Then did a rough assembly of the engines just to see whats what.
And with a fairing.
Next i covered the last of the exposed card board on the bottom of the fairings using 1/2mm (0.020) styrene sheet.
Let them dry overnight then shaped and rough sanded them
Recessed 1/4-20 unc nuts into the top of both fairings after a long and boring process of trial and error with the final location.
Covered these nuts with top plates for each fairing after gluing the nut in position
Fixed small aluminium brakets i found in my hardware stash to the wooden wing supports
Then attached the fairings for a test run
Finally painted and fitted the actuators to the back of the engine deflectors
Next is permanently fixing the fairings to the wings with a bit of a deflector at the front, will do a few mock ups in cardboard first.
Thanks for looking
Comments welcome
The Gag
[attachment deleted by admin]
Re: NYLON GAG MK 1?
I haven't commented a ton on this build, but I've been following it. Man, I gotta say, this work is really impressive. I mean, clean build, no glue gobs. You have some really tricky angles in the body, the detail on those engines is sick and curves too. All that and more.
Really cool. Large, and very cool. Keep going.
Re: NYLON GAG MK 1?
Looking better and better, Gag.
Any idea on the finish line for this?
How big she going to finish out?
Re: NYLON GAG MK 1?
Mornin All,
Thanks for the comments guys.
Iain that video is awesome, i always loved the Muppets. ;D Thanks Mate.
Just been plodding away, had some trouble with inspiration during the middle of the week. I couldn't decide what to do next. I was over thinking everything and there for achieveing nothing, so i just went with the flow. 8)
PIX
Had the dilema of how to attach the engines but still have the ability to mess with the wires and everything.
So first i made covers.
Then i decided on how to blend the fairings in with the covers
Filled then sanded
Started the detail around the forward strobe and how to run the wires to the LED.
Added the rear green/right hand side, red/left hand side flasher lights.
Did everything again with some more added detail.
Not sure what to do next, will probably do a simpler version on the inside.
I decided I want to keep the wing surfaces fairly detailed and also have some raised panels. Think a bit 'Falconish', sort of retro fit by the pilot.
Anyhow'syourdaddy,
Thanks for stopping by
The Gold Medal Gagsterman
Re: NYLON GAG MK 1?
Love your detailing NG!!! Flat Out Awesome!!! ;D
Re: NYLON GAG MK 1?
Nice work Gag, this is turning out great.
Its also turing into quite an epic build, can't wait to see how it turns out
Re: NYLON GAG MK 1?
Phenomenal! :eek:
You're a genius Gag! Can't wait to see what other surprises you spring on us.
Re: NYLON GAG MK 1?
I'm gonna say it again. This is OUTSTANDING! Your choices of what to put where are superb. Always looks spot on. Nice job!
