RocketFoot
- Sep 7, 2023
I have my paint scheme all figured out and it looks like I'll be using some Krylon Fusion, that I got a great deal on through work, for the main body, frame and interior tub. It is supposed to be a primer paint with excellent adhesion to multi surfaces including plastic models. I assume the paint is a little thicker so it doesn't require a primer so I will have to watch my coverage to prevent panel lines from disappearing. No problem there, I plan on scribing my panel lines and accenting with Tamiya black panel accent...so can I spray without a primer? Or should I still light coat with Tamiya white Primer?
What should I use to surface prep the plastic? On metal I'd use thinner to remove any dirt, grease or oil but on plastic??
What about a clear coat to seal the paint and decals? I have head a lot of good stuff about Quick Shine Multi Surface Finish which I would like to use if it is safe for Krylon paint? My second choice is Tamiya X22 Clear, but is it safe for clear coating Krylon and decals?
Sorry for the questions...this is my first model paint job and I wanna try my best with as little prep and material problems as possible, LOL!
