Thanks for the encouragement guys. Another update. I have a small box of parts that I've finished which all will be added to the LM as the thing gets closer to the finishing line.
Here are the two astronauts Armstrong and Aldrin. I scratch-built the antennas and the camera. These guys are tiny at only 1.25 inches tall at best and were a lot of fun to detail. The visors are just Testors gold paint but I put glossy black down first. I'm surprised how well they came out. I was going to use gold leaf but that stuff comes in 50-100 sheets at a time and would break the budget for this project.
This very tiny spool is a small vent on the back of the ascent stage. I'll photograph it again once I mount it in place. My camera has a limited macro feature and this is more-or-less as close as I can get to it. there is a hole drilled through the middle of the core that you can't see (no one will see), but I put it there for accuracy and because I'll know it's there at least.
This is how I apply the black painted foil to the model. I first cut a piece of paper to the exact measurements. This is easier than it may first appear since I press the paper over the model and that makes the paper crease at the correct point for me to cut along. Snip, snip and I have a perfect fit.
I then put the paper template on the foil and cut it out with a #11 knife.
I then press it onto the model. As it goes down it wrinkles a bit which is just perfect for the look of these panels. I'll later come back and put in the rivet detail with a pin. (I'll shoot that when I get to it)
I've applied bare metal foil to the front of the ascent stage and added docking lights (the little white dots) which are actually pin heads painted glossy white. I'll later add red and greed dots to these.
In the upper part I added a small area of gold foil. This will be "just" visible between the forks of the docking radar dish so it's another of those "only I will ever know unless you look really hard" details. More later.
