this other thing I'm building
Nah - It's only a thin layer of Aves .
Probably around 3-4 mm thick on average .
I was able to work the inside surface with a stick ( bamboo skewer poked thru from the opposite end ) -- the other end get's a totally different treatment , so that technique isn't required , or possible , for the " back-side " .
Thanks , Q
:D Long way to go .
This assembly is only maybe 20 % of the build .
I'll be posting more pix tomorrow .
The voids above and below these tubes were filled with this foam prior to closing them off with the Aves :
And Thanks
@ aussie cylon for naming this thing : B.E.R.T.
It's even the perfect acronym for what it will be , eventually .
Been needing a name since the start ! :D
