Thanks for your comments guys, they are appreciated!
So... the dry transfers are done:
A couple of light-weight clamps to ensure a good tight fit on the leading edge of the now varnished deck. I used one coat of satin, then 2 light coats of dead flat varnish for the seal. The leading edge of the flight deck takes a very small curl downwards right at the end, and I wanted to make sure the wood deck stayed down there:
Side tubs added, they are of the light grey parts you see down the side of the black deck parts:
Here's 3 pics of the photoetch support beam structure (that will soon be 80% unviewable as the small plastic deck part that you see sitting in the background will cover quite a bit of it, but the leading edges and the sides will be in full view). Last look at this part in its entirety before adding the other deck part on top:
Added the deck part, clamped fairly well so I could avoid using any glue near the edges or on the pe itself:
Thats it for now, but progress should go more quickly in the coming week. Thx for viewing..and, as always, comments are most welcome! Cheers, Tim
