Posts added to the bow deck, just about ready to install the decks on the hull. I have some work within the hull to complete first (mounting nuts to be attached) and I wanted to test the LED lighting as well. The spars extending to posts have not been glued in place yet as I wanted to leave a little wiggle room for the time when the bottom of the posts are attached to the hull.. and they may be moved slightly. Once the posts are in, both top and bottom ends, then I'll glue those spar extentions in place.
for a small update...I have the middle deck (first pic) permanently installed now(2nd pic):
Misc pic of the superstructure:
Props, shafts and rudders installed also:
I will have better pics tomorrow from a lower angle so you can see the photoetch as installed.
Also up next is the bow deck, so be sure to check back! thx-Tim
Here' some shots of the decks that are permantently installed now. The pics look a little strange because I placed the model upside down on its deck, took the pics, and turned the pics 180 degrees. But I will have more pics tomorrow in a regular orientation.
Thats it for now...but be sure to check back! Thx for viewing, Tim
Thanks Scott! Well, this build is over a year and a half now...and I didn't have an entry for the last CAMS Show because of it, which was a bummer because I enjoy participating in that. I went to the show of course, and enjoyed myself, talked to some great guys and saw some wonderful work...but its more fun when you have a model entered of course.
I will have one this time I think! There's still quite a bit to do, but the show isn't until the end of May so chances are good I will be participating again. That show deadline is a motivating factor sometimes!
Bonus pics I wasn't going to post these two, but I like to add a pic with every reply:
Thanks Quaralane! Your continued support is appreciated buddy!
Anyway...got the deck elevators and their covers done and installed. I had to shim one of the elevators to bring it up so the level of the elevator cover and the level of the deck would be identical:
And a couple of overview shots showing the elevator covers installed: (the forward elevator will be in the lowered position, with a plane with wings folded, in it)
I will be adding some more pe to the flight deck and I will be also be starting the island right after that. SO be sure to come back and check them out! Thanks for viewing... and any comments or suggestions are most welcome. -Tim
