Thanks guys working on the vector rings detail and
getting them attached in a temporary way. I found these
little tabs in the Morser Carl kit so I used 4 for each vector ring.
The rings slide on and off right now so I can remove the engines.
Finished the detail on the engines.....I
used some evergeen strip channel strip
and right next to each side of the channel
is a sliver of strip. It looks good but you can never see
it without primer.
Parts lay out o far....
Ok so the pvc part i had was to small to fit
the flash light reflector and to smalll inside the engine,
so what to do?
Form it.....
Ok it fits good inside the engine now but the reflector
fits a bit sloppy inside.......so form over that as well to
increase the size!
Now it fits snug and a 5mm LED fits so tight
i don"t even have to glue it.
