Papermodder
- Jan 2, 2013
Good afternoon.
With the turret mostly done, I thought it would be good to start constructing and installing all the stowage.
Started with all the packs and rolls around the turret.
With those installed, moved on to the helmets. As built these come out rather squarish. To fix that I used a damping tool to round them out.
These were then glued into place around the turret.
The next thing to tackle were the logs. The supplied ones just didn't cut it for me. Instead what I did was to cut lengths of 3/16" dowel. These were first painted with a coat of burnt umber and left to dry. Then coated with raw umber. When dry they were sanded with a 60 grit sanding sponge, to give them the look of a rough hued pine log. The ends were recut to give a fresh cut look and then glued in place with the supplied straps.
Today the hatches were constructed and installed. It was interesting that the outside half of the crew commander's hatch periscope was not included. This was easily remedied by reprinting the part and gluing it in place.
This is where she stands this afternoon.
Thank you for following.
Jim
Jim
