Hello Anthony!! Happy to help with the question. The answer would be Yes! ;D After a quick clear coat, I spray the Hair Spray/chipping fluid on. If the surface is still wet I will sprinkle some salt where I like. If dry, and the AB right there, spray a little more add some more salt. Before going onto the paint, I spray a light coat of HS/CF on the salt to keep it in place...and yes, I wait till this is dry. Then Paint.
At this point you can do a couple of things if you like. Wait till the paint is dry and chip the salt. Clear coat again and use either more salt or just chipping fluid and repeat the process using different shades of the same paint of completely different colors, or, leave the salt on add more HS/CF and then paint again.
In both instances, you are creating depth the the paint work. Each layer will enhance the dimension a little more. Once you get to the weathering stages everything will just come alive!!
I hope this helped a little.
I also realized I would probably get a beating if I did not update this. I have been pretty busy with life's little chores this month and have slowed down this past week. But the end of that tunnel, I think, is near. So with that, I moved onto getting some things together on this. I needed to keep things separated as long as possible to allow me to paint many sections a lot easier. But I am at the stage where it needed to come together so the weathering will be blended fairly evenly over the entire model.
Blah Blah Blah.....pics......... :
I mounted the engine and of course the hood. You cans see I was impatient and began adding some leaves to the block.
After installing the hood, I went back to the AB and dusted lightly another thin coat Deck Tan/Light Sea Grey as I did earlier. This blends the fading from the hood to the cowl and onto the rest of the piece.
You can see the grill is precariously hanging there. This will undoubtedly fall off at some point before final placement of the piece...just par for the course. I needed to see how this looked.
Just about ready for some washes and streaking...grime that is. I also need to come up with a "quick-n-dirty base too.
As always, thanks for stopping!!!!
TBC.....
