Looks like it's has very good detail.Didn't have a lot of time tonight but I made a start and got some of the conning tower together.
FYI. Brother, you might want to remove your card showing your last name and repost.
Good catch Gary. Much appreciated brother.FYI. Brother, you might want to remove your card showing your last name and repost.
I have done a few of their kit's, the instructions are a bit vague sometimes. I often look ahead on the sheets to check I have fitted the part in the correct place. PanthermanThis is my first ICM kit and it looks pretty nice. Couple different options for conning towers depending on which U-boat you want. I'll be doing U-23.
I have gone the other way and started working on the interior first. Thought I'd get that finished and fitted, then mask it off so I can concentrate on the outer hull and features. Also, I noticed alot of small parts that I am bound to knock off and loose. PanthermanThat looks awesome.
I got my hull primed last night. I screwed up some. Was wondering why primer wasn't going on right. After the 1st rd I realized I added thinner to primer like I was painting.
I have a few spots I need to touch up…..this time without thinner.
Nice. PanthermanHere is what I am going to build, the Mikro Mir 1/350 scale Soviet Papa class sub.
This was the fastest submarine of the Cold War. Twin screw, twin reactor, reached speeds of 47 knots submerged. The reactors were never run at 100% power, at about 97.3% the boat shuddered, vibrated, and made a lot of unsettling noises and was not pushed beyond that point. It was very noisy, thus easy to track, but NATO had nothing that could catch up to it.
That's looking really awesome!That looks awesome.
Started doing the decals as they need fitting prior to assembly. Slightly messed up the middle decals in the coning tower so I might paint them over later on depending on what you can see when it's all together. PanthermanThis is going to be another monster build. I hadn't realised just how big the kit was. Loving the details, certainly seems good value for the money. Pantherman View attachment 111591View attachment 111592View attachment 111593
Looking very nice! Did you paint the dial hands?Started doing the decals as they need fitting prior to assembly. Slightly messed up the middle decals in the coning tower so I might paint them over later on depending on what you can see when it's all together. Pantherman
View attachment 112395View attachment 112396View attachment 112397
Decals for the panels but I will need to highlight a few area's with the ultra fine brush and panel wash. PanthermanLooking very nice! Did you paint the dial hands?
